How to Use Revit Model for CNC machine ?(.btl file )
josemukalel
josemukalel
Hi
Anyone can guide me that how to use Revit model for CNC cutter ? I don't have any idea about CNC cutting.But my boss asking me to create .btl file from Revit for CNC cutting. How can i create ?is that possible? If not what is the solution?
Jose George
Architectural BIM/CAD Technician
[email protected]
+64 22513 0828
A KUDO is always welcomed; However, WHEN the above answer helps and/or clarifies your query; kindly mark it with ACCEPT AS SOLUTION
L.Maas
There is no direct way from Revit to btl and not planned for as can be seen HERE.
So you would have to look at the other end (CNC machine software) to see which files it can import.
Might be that exporting to dwg from Revit is an option, as this is a common file format that many software will read.
Also note that Revit is mainly used for designing buildings and not really suitable for product design. Probably other software might be much more useful in this respect (something like Autodesk Inventor)
Louis
Please mention Revit version, especially when uploading Revit files.
