I have a default area parameter and a text based parameter for the area per occupant which I manually enter into each areas' properties like so:
I want to now create a formula which takes the area parameter and divides it by the area per occupant to get the load. How does one do this? Thanks
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Thank you and thank god it allowed me to do this with an area schedule because room one wouldn't have worked, but I need the occupant load to round up no matter what the decimal amount is so .1 = 1 person. How can I do this?
I somehow got this to work: https://forums.autodesk.com/t5/revit-architecture-forum/round-up-calculated-total-of-revit-schedule-... HURRAY!!! Maybe an architecture based program could include this ****!
