There is a problem when use the command.
When I select a generic model like the cylinder in the picture and select the second model that need to be cut out like the cuboid,I can't get rid of the cuboid model which I used to cut out because if a i delete it than the cylinder would revert back to original form.
Is there a way to get rid of this or Am I just using the command the wrong way?
Gelöst! Gehe zur Lösung
Gelöst von Corsten.Au. Gehe zur Lösung
Gelöst von jair_gh. Gehe zur Lösung
Hi
You have to model using Voids and Solids..
little different from Modelling in Autocad where we used to cut one solid from another solid..
in Revit, you would need Void to cut through some solid...
Best of luck
