How to use an image from Manage Images
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
1874 Aufrufe, 4 Antworten
I have created a Keyplan that I saved as an image.  The image is stored in the Manage Image dialog box.  But how do I use this image? I can't seem to find a way to save this image out of the project or even better to be able to place it in a Legend to create my Key plan.  Any suggestions?
How do other people create Key plans without have to "duplicate as dependent" 100 different times for every sheet?
Thanks in Advance
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
If you saved the image by using right click on a view and Save to project as Image, then the view is saved under Rendering Category.
 Open that view, select the image, and CTRL+C to copyclip it.  Create a new Legend view and CTRL+V to pasteclip it.  Now you can use this Legend view on as many Sheets as you want.
Nachricht 3 von 5
als Antwort auf: ToanDN
Could you explain a little more? This is what I would like to do but I don't know how to get the image from the Image Manager to a Legend...
Nachricht 4 von 5
See my edited post.
Nachricht 5 von 5
Perfect, Thank you!
