How to turn off space and volume calculation in revit 2020?
LanggamanXavierMassed
Message 1 of 10
How to turn off space and volume calculation in revit 2020?  I've been on a revit article that tells how to turn off space and volume calculations but I could not see any "select" or "clear" buttons it was saying. thank you
Replies (9)
Message 2 of 10
this is all you have control over...
Message 3 of 10
so you can't turn it off?
Message 4 of 10
You don't.
Turn it "off" that is.
What is this tutorial about?
It's just strange that you are being instructed to turn "it" OFF. What are you learning about?
Message 5 of 10
Hey, @LanggamanXavierMassed : post a link to the learning resource you are using.
Message 6 of 10
martijn_pater
I think it is just a bad description: "On the Computations tab of the Area and Volume Computations dialog, under Volume Computations, select (to enable) or clear (to disable) Areas and Volumes."
@LanggamanXavierMassedThe descriptions for select/clear are not buttons ie.
You can just disable volume calculation by selecting "area calculation only" in the dropdown under the architecture Room&Area tab.
Message 8 of 10
hmunsell
are you looking to remove the unused spaces from a schedule?
if that's the case make a space schedule with Area information included. then filter and delete the spaces that say Not Placed that you don't want.
Howard Munsell
Message 9 of 10
no. but I will take note of this cause I'll need it in the future, thank you.
I was just searching for ways to increase revit performance.
Message 10 of 10
mikewp90
I agree this needs to be something Revit can do. Performance is terrible unless you're working on a small model.
