How to turn a mültystory stair to a normal stair.I can disconnect levels but ıt still behave like a mültistory stair .Cannot editable
You need select your stair then appear the option disconnect levels in the new palette and select the levels that you want to remove in your multi story this is for 2019 y recommend you use an elevation view for that, for the later versión you have this option in properties and you only need to tell if you want multi story or not .
In 2018 and 2019 you cannot revert a Multistory once it's created. It's irreversible, similar to converting to Component to Sketch-Based.
