How to trim structural beam system to beam system boundary?
4 ANTWORTEN 4
Nachricht 1 von 5
1162 Aufrufe, 4 Antworten
I have created a structural beam system as a way to make floorboards on an external deck. However the floor boards simply overhang the boundary of the beam system roughly and do not cut along the boundary. I have found a (slow) workaround by extending the start and end of each board by 500mm (so as to overlap the boundary) then selecting each individual board and cutting it to a reference plane that follows the beam system boundary, but is there a more efficient way?
Tags (2)
Beschriftungen (1)
4 ANTWORTEN 4
Nachricht 2 von 5
ennujozlagam
als Antwort auf: Anonymous
the proper way is to edit your beam system boundary line. thanks
Nachricht 3 von 5
als Antwort auf: ennujozlagam
@ennujozlagam whilst that makes the beams follow the boundary (to a certain extent), what I am after is how to trim them to the boundary. To take your example: see how the I-beams just end abruptly at the boundary line rather than the boundary line cutting them nicely along the angle. I want them to be cut at the ends along the angle.
Nachricht 4 von 5
martijn_pater
Why a structural beam system? Think I might do it as (structural) floor and use parts to create the boards.
Nachricht 5 von 5
ennujozlagam
you can use reference plane and use cut geometry > select your beam and then your reference plane. thanks
