How to trim extension of Rail Structure
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
tonkata
1511 Aufrufe, 3 Antworten
Using the Railing Tool to create a handrail on top of a wall (see image below). I can't seem to find an option on how to trim the second rail structure extension?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: tonkata
Extend the Top Rail instead of trying to remove the exceed lower rail.  See screencast in a few minutes.
Nachricht 3 von 4
tonkata
als Antwort auf: ToanDN
Appreciate the solution... In my case I haven't used the "Top Rail" as my top handrail, therefore when I attempt to tab to edit the rail, it won’t let me select the “Top Rail”.
Never mind, I will just amend my rail as per your suggestion.
By the way, is there any way in changing the surface colour in plan? I've tried override graphics in view, but unfortunately it has not changed it from grey.
Nachricht 4 von 4
@tonkata wrote:
@@ToanDN
You can change the material of the Top Rail.
