how to transfer project parameter from one revit file to another revit file
ran1602016
ran1602016
Hello All,
 Please help
I want to transfer some parameters as attached below from one revit file to another revit file how to do?
TripleM-Dev.net
The actual parameter itself I assume?
Use Transfer project standards (https://help.autodesk.com/view/RVTLT/2024/ENU/?guid=GUID-2A49FE80-1B07-4C95-A0FE-42CE2001F3C2 )
If you only need a set of parameters, make a copy of the model delete all unneeded parameters and then use that to transfer them
- Michel
