I need to copy the data of a family to other family file, can I do that?
Thank you.
You have to elaborate more on what you need to do exactly (e.g screenshots, upload families).
What do you need to copy? And in what are the differences/similarities between the families?
Louis
Please mention Revit version, especially when uploading Revit files.
What I need to do is copying the parameters of a family, for example:
Capacity: 24 L
Be able to transfer this data to another family.
Note sure if this helps:
https://apps.autodesk.com/RVT/en/Detail/HelpDoc?appId=8481526687890452659&appLang=en&os=Win64
You could ask trial to give it a try.
Cheers, K
Kunal Tuljaram Gaidhankar
Is it a Shared Parameter? Insert it into other family via your Shared Parameter .txt file. We use Rushforth Tools to manage Shared Parameters between families. Works well.
