I created my Toposurface from inserted CAD survey. I lined it up approximately. Project Base Point shared Site at 000 North 0 (please see attachment). How can I line it up perfectly ? How to trace ROADS and PROPERTY EDGE LINE to my newly created Toposurface to be saved and visible there ? I know how to change it to Wire Frame and use Detailed Line tool. I have tried to do it but I can not see it and I need those lines of Roads and Property Edge to be visible on Toposurface. Thanks
Gelöst! Gehe zur Lösung
Gelöst von Redrunner92. Gehe zur Lösung
First, use Model Lines rather than Detail Lines to make the lines show up in all views where they are visible, as opposed to only the view in which you drew them.
Second, try using the Property Line tool under the Massing & Site tab. These are essentially a specific kind of model line with extra built-in functions which normal model lines do not have.
Third, "Roads" as a category is not really accessible. See message #8 by Jeff Hanson in this post:
https://forums.autodesk.com/t5/revit-architecture-forum/how-to-create-a-road-in-revit/td-p/2398087
Oh, and fourth, use the Pick Lines tool when you are drawing lines, then pick the lines you want to draw over.
Yes, I forgot attachment here.
Problem is in order to trace lines accuraly, I need to line up my Toposurface to CAD survey file that is under it (look picture) because I moved it approximately but not exact. Project Base Point shared Site at 000 North 0.
Is there any REVIT tool that allow me to line them up to be perfect match and keep it in fixed position ? Please advise on how to do that ?
You could right-click > Override Graphics in View > By Element > make the toposurface partially or fully transparent, then use a combination of the move and align tools to line up your toposurface to the DWG file's lines.
Once you have the toposurface in the proper location and alignment, you can pin it using the Pin tool so it doesn't move:
That would be impossible if you look closely at my picture. It is real mess with those lines. I have noticed that most lines are not line up at all. Was it rotated somehow when it was created ?
I guess question is. If I will delete all and start it all over again: loading Survey and creating toposurface from it. Will it be perfectly lined up - that would make sense if it would. I do not get why it does not and why it moves if it should be attached to each other. I sow no pins anywhere when I did it.
