How to to create the small building map overview that shows where the current view is in the building(level and hatch)
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
bogdan.petrescu63URX
410 Aufrufe, 2 Antworten
hello guys,
the need has arisen to create that small building "map" that shows where the current part of the building showing in the sheet is actually located inside the building.
The building being big and split up into several parts and levels of course.
something like this (del means "part") :
i tried googling for it but i don't even know the english word for it.
tried to "reverse engineer" one but time is short.
thanks!
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: bogdan.petrescu63URX
@bogdan.petrescu63URX
It is called a Key Plan...and there a couple of ways to do it. If you google/bing or youtube the keyword you will find loads of entries starting from a generic annotation symbol ending with parameteric Lines and filled regions on the title block
Easy stuff
https://www.youtube.com/watch?v=_MKy1RWT_6c
https://knowledge.autodesk.com/support/revit/learn-explore/caas/video/youtube/lesson/143566-courseId...
https://www.youtube.com/watch?v=BZGGDcs8DjI
And over complicated stuff like this guy here
https://www.youtube.com/watch?v=Gl-qA2RufXA
Nachricht 3 von 3
als Antwort auf: RDAOU
yes!
that was what i was looking for.
thank you so much!
