Hello, how can I create such a Schedual so that their sum is calculated automatically.
[ The subject line of this post has been edited for clarity by @handjonathan Original: Schedual]
Gelöst! Gehe zur Lösung
Gelöst von handjonathan. Gehe zur Lösung
Gelöst von Simon_Weel. Gehe zur Lösung
Revit schedules don´t work in that format. Instead of columns, the types of apartments would be rows, and then you use the Sorting & Grouping tab to organize those rows per level, and for getting subtotals. You can get the same results but in a different format.
Hi @sabamail65
Thanks a lot for posting your question to the forums! Has the solution suggested by @Alfredo_Medina helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
You have to be creative and create several Schedules and superimpose them on a sheet.
Thanks for getting back to me @sabamail65
As @Alfredo_Medina suggested, it's impossible to create the schedule as you require, but it would need to be sorted & grouped by row rather than column.
Another way would be to create different schedules and add them as per the workaround suggested by @Simon_Weel
Hope this helps, but ultimately it's not possible to get it as you require with the current functionality.
Jonathan Hand
