I have a stacked wall which I'd like to add another segment to. The segment is flush with the interior of the wall but recessed slightly on the exterior. In the preview everything looks exactly the way I want. When I click to accept the changes (and this happens every time I make a change to this wall even when the segments are the exact same width and same components except its core material) numerous errors come up saying walls and roofs need to be unjoined, dimensions need to be deleted, and the wall moves slightly for absolutely no reason causing a massive headache. I even set all the walls location lines to the same part of the wall. Why does Revit do this? What can I do to not make it do this?
