I wanr to split face for curved tile (pattern based), but seems unable to pick points at edges of the surface (not as normal family), and U-V grid not applicable for split face.
Please advice,
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
What about adding a Profile (Add Profile)? That get you to where you want to go?
Hello @barthbradley
I had firstly tried this way (add profile or ) cutting) before, but I woder it was the reason of the problem of "missing tiles" in the host family, see this post
Based on that post, missing tile does not happends if a highly simplified tile is nested (2AP, 2 profile, no cutting) , but once added 1 more profile or void, missing tiles appears.
I appreciate if you could advice on either of these 2 issues (missing tile or split face), Thanks
The repeater doesn't fill because your tile still doesn't flex properly when the host is bent exceeding some threshold. Adding profiles to the form is not going to fix it because when Revit cannot create the form, it cannot add profiles to a non-existence form.
Go back to your family and drag one of the driving adaptive point using the XYZ arrows and see which part of the family break, then you know where to start to fix.
I'm pretty confused right now, @heichan88. In your other threads, this was a 4-pt. Adaptive Point Family being used as a Repeater on a Divided Surface. This new Family is a Rectangular Pattern-Based Curtain Panel. I don't understand what the issue is now. I'd like to see the file showing the "missing tile" issue. Can you post it?
...I'm surprised you can get it to work at all. It fails on every divided surface I try.
Hello
I am trying many ways for a stable tile (repeater or pattern), could you take a look at my RFA attached at the top of the post? This current tile is 2 AP profile and nested to pattern based (because previously 4 AP repeater was over-designed and also not stable).
please advice any stable way then I would try again.
If another approach can make the tile stable, please advice
Hello @ToanDN
That I had tried (just for testing), even the spacing is adjust back to standard 265x265, error still happen.
Attach RFA (as posted nefore) is the roof family which contains the final result after the tile nested. please feel free to have a look.
In the old days of Windows Vista through Windows 2.01, CTRL+ ALT + DEL was one of the most viable solutions to most problems...It still applies to some even today. If you ask my opinion, I think that you should maybe consider a RESET ![]()
Edit the profile family, delete the point below. Then reload it back in your curtain panel family and see if the family still gives the errors when you flex the spacing.
hello @ToanDN
I set this point to be the "only point to change location of the other edge of tile“ along with the curve pattern grid, while all the profile shape is fixed. if this point is deleted, the tile edge (red point) seems will not incline following patterm change (blue).
Or please kindly advice if this point be deleted, any way that red point of tile can incline along the curve pattern grid (while the profile shape unchange?)
Many Thanks
@heichan88 wrote:
hello @ToanDN
I set this point to be the "only point to change location of the other edge of tile“ along with the curve pattern grid, while all the profile shape is fixed. if this point is deleted, the tile will not inclide up to the curve.
Or please kindly advice if this point be deleted, any way that tile can incline along the curve pattern grid.
Many Thanks
I don't see any significant different to the form after deleting that point. Here is the result:
Glad you got it solved yourself. I use Revit 2022 so sending you the family would be of no use.
