how to sort this issue with autodesk material library missing
mohammedansar_a_m
mohammedansar_a_m
kindly see the attached image
how to add the autodesk materials library . it is missing as i reinstalled revit
GustavoUbriaco
It's installed you can compare if you open Autocad the Autodesk Material Library It's available BTW If you try to add in revit material gallery it appears like empty but in asset browser it's availabe
Gustavo Ubriaco Contreras
mohammedansar_a_m
i am sharing a screenshot of a autodesk official video.
kindly see the image
how to make it load in a similar way such that both " AEC materials" & "autodesk material" folder are there when i open "material browser dialog box" ( i mean similar as in the screenshot)
is there any way to download the .adsklib file for (Autodesk materials)and paste it in the directory ,so that it will work
GustavoUbriaco
there are no way to fix it Smiley Frustrated I've tried these days and nothing I guess the solution comes in an update
About the .adsklib actually it's in the computer but revit 2019 can't read it
ryan
Bump.  I am having the same issue and am having trouble finding a solution.
cbcarch
Have you tried a REPAIR of the Revit installation?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
This worked for us in Revit 2019.2
Although not sure what causes some users' libraries to become faulty
