How to sort sheet based on the last four digits of their sheet numbers
4 ANTWORTEN 4
Nachricht 1 von 5
jpnipun621
358 Aufrufe, 4 Antworten
Hi everyone,
Im working on a project in revit and i need to sort my sheets based on the last four digits of their sheet numbers (as highlighted in screenshot). I have done it in sheet list in schedule by using dynamo script. but im struggling to sort it in sheets.
Any help or insight would be greatly appreciated.
Thanks.
4 ANTWORTEN 4
Nachricht 2 von 5
vitorbortoncello
als Antwort auf: jpnipun621
Right click the browser- go to browser organization-sheets-create new or edit an existing-group and sort by the paramater (yours seems like sheet number)
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 5
So, it sounds like you want to sort the Sheets in the Project Browser via the Schedule's Parameter named "LAST FOUR DIGITS". Is that about the size of it? If so, where's that "LAST FOUR DIGITS" Parameter coming from?
Nachricht 4 von 5
Are there any duplication, for example, do you have any four-digit more than one?  If not, then use your sheet number for four-digit and add another shared parameter for the prefix XX/XX.
Nachricht 5 von 5
handjonathan
Hi @jpnipun621
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @vitorbortoncello @barthbradley @ToanDN helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
