I'm quite new in Revit, I have a .rvt file which I want to export in .obj format.
My file size is about 8MB, but when I export it , the obj file becomes more than 1GB, and the number of vertices is more than 11 million, number of faces more than 10 million. How can I change my model in revit in order to simplify it?
Thanks in advance!
Try purging the project file. You can find it in Manage tab -> Settings Panel.
I've tried what you said but it didn't change the complexity of my model. Is there a way to reduce the vertex or face count in Revit?
Change walls to single layer...remove any excess elements that are not needed, like ceilings, lights, furniture, etc.
Exporting to DWG then opening in Sketchup helps too....but it's a lot of work.
