Have an odd shaped 4 inches thick exterior concrete slab that indicates the existing concrete deck around an odd shaped existing pool with curves. The pool right now is indicated with an odd shaped hole in that concrete pad.
How can we show, with a single plane, the water inside that hole to indicate the pool water, and maybe about 3 inches below the top of the surrounding concrete deck?
The pool water volume and shape would not change, so the subtracted volume below the water is not important, only the water (to occupy the hole) have to show in the 3-D of the house (maybe at some future date I might also ask how to show the concrete volume below that holds the water, but at this moment that is not important).
Thanks in advance.
