How to Show Only Numbers Below Cut Plan on Stairs?
1 ANTWORT 1
Nachricht 1 von 2
justinealfreda.fabian
1042 Aufrufe, 1 Antwort
How to show only numbers below cut planHow to show only numbers below cut plan
On Revit 2020 - 20.2.12.1: How can I modify the Stair Tread/Riser Numbers on Plan to only show below or only show above the cutting plan/cut line?
1 ANTWORT 1
Nachricht 2 von 2
Use a Masking Region to hide 'em if you half to.
