I used a Filled Region to add a Diagonal Crosshatch to a floor plan (the crosshatch is to show existing floor tiles), and after doing so, the furniture that was shown there is not seen any more. Any reason? Or, another way to put the question, is there any way to show the furniture over the Filled Region Diagonal Crosshatch?
Thanks in advance.
Edit Type of the filled Region and make sure the Masking property is unchecked
Alternatively, instead of filled regions, you could use the following to achieve the same in a more efficient way
I unchecked the masking region, and now I see the furniture but with very thin lines, and also, the crossed hatch pattern under the furniture is seen (this is still a major issue), so the next related question is how can I hide the tile hath pattern under the furniture, and the second related less important question, can the line work of the furniture be heavier so the furniture stand out?
Filled Regions are Detail components so they always stay in front of model elements. I am not sure what your filled regions represent but you should have use Room Color scheme or actual Floors with surface patterns by materials or by view filters.
That's the thing about filled regions... Therefore you need to work with the alternative suggestions given in my initial reply
