hello everyone,
after a lot of useless search I hope that you will help me.
I have a composite wall (plaster, concrete, thermal air) and I want to present it in 1:100 scale with the main material whice is concrete, so a wall with diagonal pattern.
when I try to do it with filters the common lines between the layers are visible so the pattern is not unify (see the picture).
thank yu for your help!
Gelöst! Gehe zur Lösung
Gelöst von Kimtaurus. Gehe zur Lösung
thank you but I need to show 1:100 scale in medium/fine with unify pattern for walls and 1:200 scale with solid fill so I used your solution for 1:200 scale.
another solution?
If all walls need to show as solid in 1:200 then simply override walls category's cut pattern to solid for 1:200 views. Use my suggestion above for 1:100 view.
You can also set the walls category to coarse in the V&G Overrides.
That way, each wall type can have it's own coarse pattern and colour.
In the 1:100 view, set ONLY walls to display Course by doing it in the Visibility Graphics settings for that view, leaving the main view detail level setting on Medium or Fine as desired.
Please share a file with the wall on it.
