How to show all phases existing, demo, new1 and new2 in one floor plan
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
3068 Aufrufe, 5 Antworten
Hi there,
Please find attached pic.
I need to show im my floor plan all phases, existing(grey), demolition(yellow) and new construction(red).
The new construction is in two phases.
The wall inside the green rectangular is in new construction phase 2 and I need to show it as temporary and in blue.
The phase filter in this pic is existing, demo, and new, and the phase is new.
How should I set my phase filter and my phase in order to show all 4 phases in one floor plan?
Many thanks in advance.
5 ANTWORTEN 5
Nachricht 2 von 6
constantin.stroescu
als Antwort auf: Anonymous
  • Phase: New Construction Phase 2 (the last phase)
  • Phase Filter: Show All
These settings would allow you to show all the stages of the work
Constantin Stroescu
Nachricht 3 von 6
bin
als Antwort auf: constantin.stroescu
I'm afraid it will not show the demolished wall because it is demolished in previous phase.
Op either need to demolish them in the last phase, or use "None" as filter and manually graphic override everything.
Nachricht 4 von 6
When I follow your suggestion it shows all objects as existing and shows the objects in the last construction phase in red.
What I need is to show existing grey, demo in yellow first construction phase in red and the second construction phase in blue as temporary.
Nachricht 5 von 6
bin
What you can do is to have only 2 phase: Existing and New.
All existing element - Phase Create: Existing, Phase Demolished: None
Demolished element - Phase Created: Existing, Phase Demolished: New
New Phase 1 - Phase Created: New, Phase Demolished: None
New Phase 2(Temporary) - Phase Created: New, Phase Demolished: New
View Phase: New
Phase Filter: Show All (New: By Category, Existing:Overridden, Demolished:Overridden, Temporary:Overridden)
If you don't want to combine your phases, use "None" as phase filter under any phase, then manually override your elements.
Nachricht 6 von 6
RobDraw
If this is for a sheet, have you considered overlapping views?
Rob
