How to show all beams in one color and column another color
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
4165 Aufrufe, 7 Antworten
Please help me to show all beams in one color and columns in another color. mechanical ducts, plumbing, fire protection systems with each in different color. Thank you.
7 ANTWORTEN 7
Nachricht 2 von 8
L.Maas
als Antwort auf: Anonymous
Make use of filters to select based on certain parameters (e.g category, family name). Then use visibility graphics overrides to add the filter(s) and assign colors
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 8
Corsten.Au
Hi
you can use Visibility graphics, surface pattern override ..
and for few categories where surface is not available, you may use
object styles..
Graphics Override - surface patternGraphics Override - surface pattern
But if you can use workset, making the file central,
move elements in corresponding workset and use workset as a filter..
this would give you a much better flexibility  and clarity..
Workset - filterWorkset - filter
Corsten
Building Designer
Nachricht 4 von 8
als Antwort auf: Corsten.Au
Thank you @Corsten.Au and @L.Maas. I had another problem. it is i linked mechanical revit model with and architectural model. Then how I add colors for these mechanical ducts in linked mechanical model. ?
Nachricht 5 von 8
Corsten.Au
Hi
you need to do testing for Graphics..
Each and every view are independent, so PLAN, ELEVATION, SECTION and 3D
each needs custom settings ..
Use " by host " and change VG and check if you can control the graphics..
example : VG, Wall surface solid colour, this should update the link model Graphics as well..
for ducts it little tricky.. there are no surface pattern to change.. so use " Object Style "
Object styleObject style
Best luck
Corsten
Building Designer
Nachricht 6 von 8
In Visibility Graphic, there can not be change the color fill in custom as shown in below image. Please help me to make another color for duct (in linked model) which shown in red arrow in the image.
need to be change color in linked duct modelneed to be change color in linked duct modelcolor fill can not be appliedcolor fill can not be applied
Nachricht 7 von 8
Corsten.Au
Try Filter and give that filter colours..
in shaded 3d mode you should get these colours..
Corsten
Building Designer
Nachricht 8 von 8
Thank you @Corsten.Au and @L.Maas. I done it according to your guidance. Solution for duct colorSolution for duct color
