You want a View parameter value and a Sheet parameter value to be the same? How would the sheet know which view port contained the view parameter it was suppose to use?
@Anonymous wrote:
I want one parameter to serve both view and sheet family at a single instance.
It is fundamentally not working. What about Legend views that can reside on multiple Sheets?
Your best bet is create a View schedule, group by Sheets, un-itemize so All Views on a Sheet collapse to a single row, and enter the value for that row to match that of the Sheet.
Possibly an instance based text parameter that is associated with both Sheets and Views. You will, however, need to manually enter the required values.
