how to set up baseline? dimension
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
775 Aufrufe, 4 Antworten
Hi ,
Is there anyone knows how to set up or create baseline dimension like that above?
I will really appreciate your help.
Thanks.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Or is there a way to show both the  normal dimension and the  baseline dimension?
Thanks.
Nachricht 3 von 5
Look like Ordinate string (2nd image) is closed to what you need.
Nachricht 4 von 5
Hello @Anonymous,
Toan was right, Ordinate String is what you need.
All you have to do is modify few fields in the dimension settings for you to achieve the best results.
here are some of the difference between continuous and ordinate settings.
Nachricht 5 von 5
Thank you so much!
