How to set the top of footings seen "beyond" with hidden lines
1 ANTWORT 1
Nachricht 1 von 2
octavio2
215 Aufrufe, 1 Antwort
Revit 2021:
Added footings in the Structural Slab and Foundation Plan (of level 1) but the lines of the footings shown "beyond" are seen with solid lines.  This Structural Slan and Foundation Plan has assigned to it the "Structural Foundation Plan" template, and the scale is overriden to 1/4"=1'-0" (this scale works well with this plan, I was able to change to that scale).
When I try to change the lines shown "beyond", using Manage/Additional Settings/Line Styles, I can change there in that dialog box the <Beyond> line to Hidden 1/8", but then the lines of the footing seen "beyond" on the plan do not show hidden and they are still seen solid.  I wonder what the problem is that these do not show hidden.
Question:  If I am using the "Structural Foundation Plan" template on the Structural Slab and Foundation Plan viewwhere (or how) do I set the "beyond" lines so these will be shown dashed on the footings shown on that floor plan?
Thanks in advance.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: octavio2
"Structural Foundation Plan" template and "Structural Slab and Foundation Plan" view has no meaning to me. They are just names.
Post the File so we can take a look at the Template Properties, View Settings, etc.
