We have a multi discipline model. We want to set it so all exsiting floors,walls,foundations, etc. have a cut pattern of solid grey only for structural and architectural views, but the process views remain unhatched. Please help? Been trying different avenues of filters,overrides, etc but cant seem to get it figured out.
Gelöst! Gehe zur Lösung
Gelöst von juliar123. Gehe zur Lösung
If you can't figure it out with the project/view sitting right in front of you, I don't know how we can be of help. I would need to see what I'm working with. Basically, I would need to figure it out as well. It may take a combination of settings (e.g. filters, overrides) to get where you want to go.
Have you been able to get close to what you want?
- Use Phase Graphic Overrides to override (e) cut pattern to solid gray color. Set architectural and Structural views to Show Previous + New.
- Set process views to Show Complete.
Ive been trying to use a view template and then set a filter to filter walls,floors,slabs setc. to be solid grey color. but cant figure out how to get it to only filter existing.
or
If i was to set the existing phase cut pattern as grey it works for the whole model, but i would in that case want to filter out cut patterns in the process views to be no cut pattern.
What year of Revit are you working in? In 2022 and above, there is a Phase Created option for Filters.
Been trying this in 2020. and i was trying to create a phase created option in filters and wasnt sucessful with creating that parameter. im going to try it with my model upgraded to 22
