Hi !
Imagine you have to provide many options of the same room and you want to test seating and walls in different colors. Is there a way to select by a overridden surface pattern in each new view so you can easily apply new surface patern to all the seats and walls without singular selecting ? Please see an image :
Jarek
Gelöst! Gehe zur Lösung
Gelöst von RobDraw. Gehe zur Lösung
Gelöst von Avaris.. Gehe zur Lösung
No, that is not possible in Revit. I do think of this solution:
-Select all objects once that you want to override
-Save your selection
-You can now load the same selection multiple times and easily override it.
I wouldn't use overrides by element for this. Make a filter, even if it's a selection filter.
