Hi, I'm looking at a particular object in a Revit 2018 2D view, and I'd like to see it in a 3D view (or another view, doesn't matter). But when I open another view, I then have to refind that object, which is very tedious. How can I keep the focus on that object?
Also, sometimes I need to look at the relationship between two objects. When I locate that object in 3D, there are many other objects in front of my object that I cannot see it. Aside from isolating elements (which doesn't work because I am looking at the relationship between two objects), how can I "clear" space around this object so I can see clearly?
Thanks!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Actually select the objects you want in one view and then switch views immediately and Select Previous. I use use this method all the time.
...another method is to create a selection set filter. Great if you want to select all the elements together at another time in another view.
Ah ha, thanks! So if I want to show a certain set of objects (say, a bathroom) in a 3D view, I can create a filter for everything inside that room, jump to that 3D View, and then show only that filter. Very cool, thanks.
