How can I vizualize this parameter on a Schedule?
(I have made the parater with this tutorial: http://therevitcomplex.blogspot.com/2013/06/report-length-of-any-curve-including.html)
Thank you all!
Have you created the Shared Parameter per the tutorial? Have you added it to your Project and associated it to Walls?
You will need to add the shared parameter that you have created to your Schedule fields. That will create the field reporting the length of curved walls. Good luck!
Aaahh. I stand corrected.
Associate the Shared Parameter with Curtain Wall Mullions then.
All else remains the same. You may need to create a Multi Category schedule for this.
You need to add the same shared parameter to your project and assign it to the Generic Model category (assuming you created the adaptive family in this category).
