How to scale a loaded in section detail
2 ANTWORTEN 2
Nachricht 1 von 3
uaa061
302 Aufrufe, 2 Antworten
I am trying to scale in a section detail I got from kawneers website but when I load it in to my drafting view I'm unable to scale it because of the filled in regions. Also this is my first time working find drafting view for section details, so any tips is also helpful.  Thanks in advance!
Beschriftungen (3)
2 ANTWORTEN 2
Nachricht 2 von 3
jvpantin2
als Antwort auf: uaa061
Hi, @uaa061, filled regions shows accordingly to drafting view scale, this is in order to maintain consistency between different scale drawings. If you want to change region's scale, go to three dot button on right side of foreground fill pattern parameter, select pattern and then change import scale value. As good practice, recommended to duplicate pattern before, at least you're shure to change in all instances.
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
Nachricht 3 von 3
What file format is the Kawneer detail?  Is it an rfa?
