How to save a 3D Camera View position
AidanHawkins
AidanHawkins
Is there any way to lock a 3D Camera View that I have created..
So as that if I move it around a bit I have a function that it will always go back to it's same place?
constantin.stroescu
How I did it in a few of my projects , when I need to show on Plan View where  I'm looking from(I use these especially both with  render presentation in a thumbnailed plan)
  • I've created two symbols - one for Eye , the other for Target and load them into the Project
  • then use a Dynamo script
  • here you can see a rough screencast that shows how it works:
https://youtu.be/-9nafpGYbFM
Constantin Stroescu
Duplicate the 3D camera view. lock one, and adjust the other.
So, you want a way to find your way back to the same place you were standing before you moved?  What about retracing your steps?   Undo or Rewind will get you there. 😉
Undo an Action | Revit 2019 | Autodesk Knowledge Network
Retrieve Previous Views from the Navigation History | Revit 2021 | Autodesk Knowledge Network
