How to rotate a viewport in 180 °, in order to see an upturned elevation in the sheet?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
You mean "Rotate on Sheet" (Options Bar). Your picture looks like a 90 degrees clockwise rotation. 180 degrees would be upside down. You don't mean this; do you?
Hello @roblesarquitecto,
As far as I know, there is not method to rotate Elevation views 180º, but you can create a "Section View" showing the same objects that the elevation shows and rotate the view by rotating the Crop Region 180º.
Rotating a Elevation 180º doesn't make a lot of sense when reading the drawings, it may look pretty on some presentations, but lacks of functionality.
Also, I want to invite you to participate on "Comunidad de Autodesk en Español" and it's "Revit & BIM" forum (foro de Revit en Español), if you're from spanish speaking country.
J. Samuel Santana F.
¿Te resultó útil esta publicación? Dale a Me gusta.
¿Tú pregunta fue respondida correctamente? Haz click en el botón ACEPTAR SOLUCIÓN.
@ToanDN ha escrito:
Open the view, turn on view crop region and rotate it 180.
@ToanDN, that doesn't works for Elevations (it's makes sense, most of the time you want your ground down).
@barthbradley ha escrito:
Yes, he mean upside down. There is a image attached as a file.
Rotate a callout view.
...make a callout view of your elevation view. Rotate the callout as per @ToanDN's suggestion.
That's works, only thing is you have to uncheck "sun relative to the view" (because shadows get weird).
