I have a slanted wall, but the window doesn't follow its angle after I place it. How do you do it without creating a new family of windows.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You need a face based window family. But casement windows should still be plumb, even in a slanted wall, so that they can operate properly.
Here in Revit 2022 with a default Autodesk window
You will have orientation parameter on the window which you can set to Vertical or Slanted
Louis
Please mention Revit version, especially when uploading Revit files.
