Hi Everybody,
I have this Generic Face based family which was created by someone else.
It is annoyingly created perpendicular to the face it is meant to attach.
I can't rotate any of the objects or change their orientation to be on the Face it is meant to be.
I can't rotate their Host Plane even while editing their shape (e.g. sweep)
I tried copy and pasting the objects to a new family but they all appear on the same orientation as they are created.
Any ideas?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
change the orientation and origin in the family itself
if it needs to be on an elevation view manually set it in the family editor
currently it is set in a plan view, so change it to a left or right view orientation.
@barthbradley wrote:Post the family. We'll fix it.
Here it is.
This one is not a complicated one so one way I found is to individually change host of masses in 3d view. I was wondering if there was easier way without the need to put back all the objects together after Re-hosting.
@stingers80-cgarchitect: Did you not like the family I posted in #5? Just curious why that one didn't work for you.
@barthbradley wrote:@stingers80-cgarchitect: Did you not like the family I posted in #5? Just curious why that one didn't work for you.
I'm sorry. I didn't realize there were 2 replies. I only saw the last post with the family. It worked. I don't know how I wasn't able to rotate them from side view. It seemed that they were locked.
Thanks for help.
Thanks for help.
You need to check Disjoin box when you rotate it.
