How to revise family for correct hosting
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
cbt990
350 Aufrufe, 6 Antworten
I chopped up this model from ARCAT and modified it to mount flush onto a wall:
My guess is it isn't originally a Face-based family since it was floor mounted. Is there a way to change this?
It could work to have it as Work Plane-based, but when I try to place on work plane it basically allows me to place it anywhere including the wall face and empty space:
Revit is amazing
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: cbt990
Uncheck Always Vertical so that you can place it on any face or ref plane.
Nachricht 3 von 7
cbt990
als Antwort auf: ToanDN
That helped. How do I correct the orientation?
Revit is amazing
Nachricht 4 von 7
Actually I am backing up from my previous suggestion and asking you this question first: do you only want it to place on vertical surface?
Nachricht 5 von 7
cbt990
It will only be hosted to vertical walls.
Revit is amazing
Nachricht 6 von 7
Why don't you just rotate it 90 degrees in the family?
Nachricht 7 von 7
cbt990
Just going to use this one from revit city. thanks.
Revit is amazing
