How to revise family for correct hosting
cbt990
cbt990
I chopped up this model from ARCAT and modified it to mount flush onto a wall:
My guess is it isn't originally a Face-based family since it was floor mounted. Is there a way to change this?
It could work to have it as Work Plane-based, but when I try to place on work plane it basically allows me to place it anywhere including the wall face and empty space:
Revit is amazing
Uncheck Always Vertical so that you can place it on any face or ref plane.
cbt990
That helped. How do I correct the orientation?
Revit is amazing
Actually I am backing up from my previous suggestion and asking you this question first: do you only want it to place on vertical surface?
cbt990
It will only be hosted to vertical walls.
Revit is amazing
Why don't you just rotate it 90 degrees in the family?
cbt990
Just going to use this one from revit city. thanks.
Revit is amazing
