I was messing around with the roof properties (changing color, fill, etc...) How can I reset these settings back to the default? Thanks
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Probably easiest to just use Transfer Project Standards and transfer the default one from a New Project and overwrite the one in the current project.
...or rename the one in the current project and copy-paste a roof using the default settings from a new project.
Thank you very much for your quick reply. So what I'm inferring from your response is that, if a open a new project, then the family type I was messing around with will be the original, default properties?
What I am saying is that the default is unchanged in the template (rte) on which you based your current project. The default will be as it was before when you open a brand new project using that template. Check it out.
