How to Render Multiple Cameras in Revit?
2 ANTWORTEN 2
Nachricht 1 von 3
fernandovalbuena
279 Aufrufe, 2 Antworten
I'm looking for a way to render multiple cameras simultaneously in Revit using the Revit rendering engine. Typically, I render one camera view at a time, which can be quite tedious. I'd like to know if there's a method to select multiple camera views and render them all together in a single process. Any guidance or tips would be greatly appreciated. Thank you!
2 ANTWORTEN 2
Nachricht 2 von 3
jay_colcombe
als Antwort auf: fernandovalbuena
You cannot do this directly in Revit, you could use the Revit Render in the Cloud option but this requires tokens (i am sure if you use draft it does not use any - but that was a while ago) or a Third Party visualisation addin where you can take the 3D views out into the rendering program.
Jay Colcombe
Autodesk Certified Instructor
Nachricht 3 von 3
syman2000
If your company has multiple computer, you can open the model in each computer render each view. This is how we did rendering in the past before the introduction of Rendering cloud.
If you are willing to pay for extra token to render, Render to the cloud is the way to go.
If you have 3rd party software like Enscape, it has batch rendering
Also you can check
V-ray cloud rendering - https://www.chaos.com/cloud/revit
Veras - https://www.evolvelab.io/veras
