How to remove Text on Elevation Symbol
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
tstewart
264 Aufrufe, 2 Antworten
How to remove the text (Interior elevation's dwg. name & #) on the Elevation symbol?
2 ANTWORTEN 2
Nachricht 2 von 3
syman2000
als Antwort auf: tstewart
You have to edit the family. First check which elevation family it is belong to.
Right click and click on edit
Select the family and edit again
Once you are in the elevation arrow, you can delete the text or add them to parameter where you will not see them. Then load that back into the project.
Nachricht 3 von 3
tstewart
als Antwort auf: syman2000
Excellent & thanks.
