How to remove stamps on the sheets when export to AutoCAD from revit file
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
jianglideng
495 Aufrufe, 6 Antworten
After I exported CAD file from a Revit file, I deleted all other files other than dwg files. But the stamps are still there when I open dwg files.  There is a separate stamp file inserted into the Revit file(img). If I don't want the stamp on CAD files, what should I do? Thank you in advance.
6 ANTWORTEN 6
Nachricht 2 von 7
Tom_Kunsman
als Antwort auf: jianglideng
What do you mean by "stamps"? Can you provide a screen capture?
Even if it was a JPG or some other image file, once in cad you can always remove that
Nachricht 3 von 7
jianglideng
als Antwort auf: Tom_Kunsman
Please see the screen shot:
Nachricht 4 von 7
Tom_Kunsman
Once in CAD, did you try editing the block to see if it was in there?
Nachricht 5 von 7
SteveKStafford
You could set up a Global Parameter that can act on the titleblock family to turn off the stamp (nested family) then turn off before exporting.
Fwiw, many firms do not put stamps in the model or on their sheet's titleblock either because it violates the agreement with registration boards regarding managing the stamp or because submission requires a "wet" stamp. Where it is acceptable to print a stamp many firms apply them with a 3rd party application to the resulting PDF documents (Bluebeam for example). This way the stamp is never in the CAD files or Revit model.
Steve Stafford
Nachricht 6 von 7
jianglideng
als Antwort auf: SteveKStafford
Could you tell me how set up a global parameter step by step?
Nachricht 7 von 7
Tom_Kunsman
@jianglideng see this help article - https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-30CE876E-36A1-4753-B482-424FC891C470
hope this helps
