Hi everyone,
I have this custom curtain wall door that I placed in my curtain wall, but I need it to be exactly as the width of the curtain grid, instead of being adjusted to mullion size.
That door now is 1062mm but it should be 1100mm.
How can i achieve that?
Gelöst! Gehe zur Lösung
Gelöst von Alfredo_Medina. Gehe zur Lösung
"Adjust for mullion size" is a property of the curtain wall itself, not a property of its panels.
You need to define those offsets in the curtain panel family / door family
Hi @Alfredo_Medina, thanks for replying.
I thought it was the only way to solve this; there is no way to set that in the curtain wall itself for the single panel right?
No, those are properties of the panel, not of the curtain wall.
