How to remove intersecting wall / floor outlines?
3 ANTWORTEN 3
Nachricht 1 von 4
ryan_harlyn
217 Aufrufe, 3 Antworten
is there any way to hide those lines? or ill just need to edit the boundaries so it doesnt intersect with each other? thank you
3 ANTWORTEN 3
Nachricht 2 von 4
syman2000
als Antwort auf: ryan_harlyn
Use join geometry to join the wall to other wall.
As for some of the wall touching the wall above, you can use attached and pick the floor or set the offset to thickness of the floor slab.
Nachricht 3 von 4
PhilvK
Set the interior walls to stop at the bottom of the floor above?
Join the 2 exterior walls?
Nachricht 4 von 4
wisedrawing
apart from the good advice above also it looks like one you red crossed is a CAD layer or Model line layer so you can hide that one
