Hi, could you please give me advice how to remove family type. if i upload ifc export from revit to bim , object name shows in structure as name:type . i tried to remove all type from family , then in project file object name is ""family name:family name"" in bim. i need to see in bim only family name .
thanks in advance
Gelöst! Gehe zur Lösung
Gelöst von th95M9M. Gehe zur Lösung
When Exporting the IFC from Revit is the Following Parameter selected?
"Use Family and type name for Reference"
Are all the other correct names correct, but only some different or not what you expect?
Maybe your example is a model in-place family?
