Hi !
I would like to remove definitely the non used project'fields in the nomenclature list but the "remove" button is never available to do it. The parameters concerned are already removed from all the projet (in the project parameters and share parameters...). I tried to restart the software but doesnt work. You can see the picture for a better understanding of my problem !
Thank you for you help !
Charles
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Are you in a Key Schedule? I can't read the language. Looks like you are.
Are you saying that the Project Parameter no longer exists anywhere in the Project?
Hello Barth,
If Key Schedule means the nomenclature properties, yes
Sorry for the french language
Yes I'm saying that. I had added the parameters but I removed them from families since.
Ok thank you Toan !
"If the parameter was added in families then you cannot delete it." : Even if they are no longer in families since ? I removed them...
