Hi All!
I'm trying to remove the borders off my door tag. I want my door tag to be just the numbers. I can't find an option where I could opt to remove the border around the door tag number. PFA, screenshot.
Gelöst! Gehe zur Lösung
Gelöst von Lance.Coffey. Gehe zur Lösung
Thank you for the question @ahirani24!
I tried this in Revit 2022, and found the border could be removed by doing the following:
If this is not working for you, can you attach a sample project showing the results you are getting.
Or instead of deleting >>> edit the family and associate the visibility of the lines with a Yes/No Parameter which you can use in the project to create a Tag type without a box...
Out of practicality and just in case sometime in the future you decide that you want the box back it will be there still
