How do I refresh/ reload a schedule in Revit?
How do you refresh yourself? ![]()
What do you mean reload/refresh? What is going on? Is there something wrong?
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Select the shedule
move/ nudge it ( on sheet )
that should refresh it.. no kidding..
Some parameters do not refresh automatically
, it happened to me in an Assembly column. To make the column refresh I pressed the Hide/Unhide button for the column that needed to update.
Seems the newer version of Revit specially 2021 gives all these issues.
i didn't notice (nor pay attention) to tha tin 2021. But in older versions i had noticed that a schedule on its won woudl update immediately, but a schedule on a sheet would not. It will updated whne you re-open the sheet, though.
If that still is a bug, I guess just look on the actual schedule. Befor eyou actually print a plan set, you sure have closed sheets and re-opened, so they will be updated.
It seems not reasonable, but saving the file 'somehow' refreshes the schedules (for those parameters which do not get refreshed automatically!) I see this in Revit 2021
Wow can't believe it, but this works. Revit needs to fix that. Rediculous.
