How to reduce revit file
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
l.yong1
847 Aufrufe, 10 Antworten
Hi there,
Can anyone lease give me tips how to reduce revit file size?
I have imported quite a lot of furnitures from sketch up and revit furnitures.
The file seems to be very slow and difficult to work with.....not responding.
My file is too big 455,456 KB.
Thank you for your help. Have a great day:lächelndes_Gesicht_mit_Sonnenbrille:
10 ANTWORTEN 10
Nachricht 2 von 11
syman2000
als Antwort auf: l.yong1
I would purge the file first. Also sketchup or any CAD import tends to bloat your file. I would replace them with native Revit family. If you cannot do that, then you would create workset and place the those CAD/Sketchup import into workset. Then when you open up Revit file, you can turn off those CAD/Sketchup workset so it won't load.
Nachricht 3 von 11
ennujozlagam
check this previous thread and see if helps. thanks
Nachricht 4 von 11
l.yong1
Hi Syman, I know how to purge sketch up file but how do you purge revit file.
Nachricht 5 von 11
syman2000
Go to manage>Purge unused
As well when you saved, you can set to compact file
Nachricht 6 von 11
RobDraw
Don't purge unless you know what you're doing. It's most likely not going to help much and may get rid of stuff you need.
Your imported objects are the most likely the cause. Focus on deleting them and replacing with native Revit elements or link them. Once the items are deleted, there are probably a lot of categories that will need to be deleted. Most likely a lot of them won't purge and will need to be deleted manually or with Dynamo or a third party application.
Rob
Nachricht 7 von 11
l.yong1
als Antwort auf: syman2000
Thank you. I have just reduced my file from 45ooo to 10000.
Nachricht 8 von 11
RDAOU
@l.yong1
You do not need to reduce the size for better performance and definitely not a file which is 45MB !!
Nachricht 9 von 11
l.yong1
als Antwort auf: RDAOU
The file is too slow and not responding. I have no choice but to reduce the size.
Thank you for your comment.
Nachricht 10 von 11
RDAOU
@l.yong1
You always have  a multitude of choices sometimes a simple search gives you plenty to work with...Purge is always the last of them (that's if if it is about only about model slow performance)...45,000kb model is pretty much tiny :leicht_lächelndes_Gesicht:
How to improve, optimize, or troubleshoot performance in Revit | Revit 2021 | Autodesk Knowledge Net...
Revit slow performance | Revit | Autodesk Knowledge Network
How to keep the size of Revit files manageable | Revit | Autodesk Knowledge Network
Ten Best Practices for Better Revit Performance | AUGI - The world's largest CAD & BIM User Group
Rules to Improve Performance in Revit
Nachricht 11 von 11
l.yong1
Thank you for your advice.
Unfortunately it is too late now. I already unpurge my file:( Hope it does not affect my file.
