Hello!
I have reorganized the organization of my template and I can't purge the unused content of a text project parameter. It is assigned to Views.
Any idea?
Thank you in advance!
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
I have just answered to your other post which most probably will be moved...so I will reply with the same here.
Do the following:
Once no views are using the text value 1.0 Working Views and 1.1 Presentation Views, it will be deleted from the list
Are you able to share the file via cloud if not direct attachment? if yes send DM
I did a video recreating the problem and i sent you a we transfer with the rvt.
Thanks!
Go to View >> View Templates >> Manage View Templates >> Empty Values of this parameter in View Templates
